Running an engine on half compression?
Page 1 of 1 • Share •
Wondered if anyone had some wisdom to offer on this question:
On my Ruston Hornsby AP 3.5 there is a starting position on the cam for the exhaust valve that holds the valve open a bit during the compression stroke. It makes it easier to start but I've also noticed it runs nice and quiet and smooth if you leave it on that cam position just running it.
The question is whether it could cause any damage to the exhaust valve if you just run the engine at idle?
I wouldn't do it if the engine was placed under load.
Being the model with a low tension maggy it's happy to chug away at low revs.
Regards Graeme
Regards Graeme
glowes3- A true Stationary engine owner
Re: Running an engine on half compression?
now that is a very good question to ask,as i would if i was you
in my way of thinking , when running for long spells with the valve not fully closing, i would say the chance of burning the valve or seat with the exploding mixture rushing through the small gap would be acting like a oxy/acetaline torch to the valve,stem and cylinder head valve seat,
so I wouldnt want to be doing it if it was me
thats my idea on the topic ,but i maybe proved wrong by a Ruston Hornsby AP 3.5hp owner or prevous owner of one
[quote="kevjhnsn"]now that is a very good question to ask,as i would if i was you
kev[/quote]
I'd be inclined to agree with what he said.
kev[/quote]
Thanks for the replies. Burning out a valve has been my concern. However, as the exhaust valve is only open during the compression stroke and closed fully at combustion I'm not sure there would be valve burn.
Am open to be corrected.
You are to a point, it is valve overlap that changes when running on half compression. To my way of thinking it isn't supposed to run on half compression so why would you? I'd rather run on full compression and be happy I'm not doing any damage rather than run on half and hope for the best.
I know C/S diesels run on "high compression" when running light but this is done via a changeover valve in the head, not by changing the valve operation.
villiers I know C/S diesels run on "high compression" when running light but this is done via a changeover valve in the head, not by changing the valve operation.
its a chamber in the side of cylinder with a screw valve closed is just cylinder area compression, and when the screw valve is opened compression is lowered when it goes into the void area inside the screw valve, but as villiers is also saying this on the c/s diesels is designed for ease of starting and adjustment for power needed for job
Good comments - thanks.
» Frosted glowplugs; am I my own worst enemy, running too lean?
» Pee Wee Head gaskets
» anyone ever heard of a "sesco" engine
» bad compression.. how to fix it
» Cranking and running Norvel engines
