Lucas RS1 Magneto help
Post by greasemonkey on Sun Feb 08 2015, 14:18
Hello all. Having been a member for a few months now, it's time for my first question. The first of many!
Does anyone know if it is possible to obtain a manual or even a diagram of a Lucas RS1 magneto? I have stripped down my mag that came with the Lister D, but ideally I would like to have a diagram of parts. There are one or two bits missing. Is there anyone that can supply replacement parts? I know Stationary engine parts do a condenser and points, but I need one or two other bits.
Thanks for taking the time to read. I may be stating the obvious, but I am a complete novice with little or no knowledge and I am looking to all you seasoned veterans of this hobby to help me out!
Thanks in advance. Cheers,
Graham Very Happy
Graham Very Happy
greasemonkey
I really need to post more
Re: Lucas RS1 Magneto help
Post by kevjhnsn on Sun Feb 08 2015, 22:39
hi there
i rebuild the mags for others at a cheaper rate than specialists
if you can post me some pics of all the parts you have and what parts you have that need replacing that you know of, hoping not the coil £££ and the magnetic field was up to scratch,i have a few i use for parts on my shelf, if there is a manual i havnt found one yet,but they are directional so please stat what rotation from the cover clock or anti-clock
Post by Locknut on Mon Feb 09 2015, 19:12
Hi Graham,
Not sure if this helps but the Stationary Engine magazine (Kelsey Publishing) offer. for sale, a booklet entitled 'M-L Magnetos, instruction booklet for types RS1.....' - this is advertised inside the magazine's front cover.This might be useful.
All the best,
Kev.
Locknut
Post by greasemonkey on Mon Feb 09 2015, 19:38
Hi kev. Thanks for reply. The main thing that is missing from my mag is one of the metal straps that holds the coil in place, into which the screw that holds the cap on also fits. If you have one of these, that would be great. I intend to replace the condenser and the points, but if I can't get a spark then I may need your help.
Thanks,
Graham
Graham Very Happy
greasemonkey
Post by greasemonkey on Mon Feb 09 2015, 19:41
Hi Locknut (kev). I will look at my latest issue of stationary engine and order this. Thanks
Graham Very Happy
greasemonkey
Post by kevjhnsn on Thu Feb 12 2015, 02:46
greasemonkey wrote:Hi kev. Thanks for reply. The main thing that is missing from my mag is one of the metal straps that holds the coil in place, into which the screw that holds the cap on also fits. If you have one of these, that would be great. I intend to replace the condenser and the points, but if I can't get a spark then I may need your help.
Thanks,
Graham
hi graham
I do have a good coil/cover retailing strap available,
you have a pm on here
thank kev
Post by kevjhnsn on Mon Feb 16 2015, 13:54
hi graham
please see pm about your other parts request
thanks kev
