Villiers Mark 25 Govener
Engine running very fast. Adjusted the govener, turned it clockwise., but it still runs as if I have the throttle open in full position and when I return the throttle yo idel position the engine does not return to idel running ??
John Mullane- Posts : 4
Re: Villiers Mark 25 Govener
can you post a pic or pm one to me, or say what carb is fitted ??
also is the return spring still fitted, but a pic of carb linkage and engine spec ie 25r 25hs ect would be a great help in knowing what linkage type is fitted also as there are about 5-6 types from memory
I will post some photos at weekend, tks
Hi john did you fix the issue of the villiers running too fast as I have the same problem.
bobtodd- Posts : 3
» Villiers Mark 7
» villiers mark 20
» villiers mark 25
» Villiers Mark 10 - me again
» villiers mark 10 not running
» villiers mark 20
» villiers mark 25
