Carbon removal from brass
Post by Gubble1234 on Wed Feb 25 2015, 18:59
Hi all, I'm trying to clean up a Villiers Junior engine I've had for a while before I install it in a bike, but I can't get the carbon off the brass flywheel cover. I've managed to remove the carbon from the rest of the steel and alloy with steel wool, but I'm fairly sure the brass would be scratched if I used steel wool on that. Any suggestions as to what I can use?
Gubble1234
Re: Carbon removal from brass
Post by billypurves on Wed Feb 25 2015, 20:11
You may think I am extracting urine here BUT I am not......HP sauce is the one.
billypurves
Post by Gubble1234 on Wed Feb 25 2015, 21:17
Heh, HP sauce is probably one of the last things I would have thought to use, but I'll give it a try!
Do you just leave it on for a while or rub it in?
Gubble1234
Post by billypurves on Wed Feb 25 2015, 21:24
Leave it on a while..overnight usually removes all stains and tarnishes.
billypurves
Post by Woodsman on Thu Feb 26 2015, 08:25
Can't beat Brasso IMHO.
Post by Gubble1234 on Fri Feb 27 2015, 20:41
Tried brasso, but the carbon is in the grooves of the brass. I was sat there rubbing the same spot for 10 minutes and it didn't budge! It ended up being a very shiny bit with black lines on it.
Gubble1234
Post by kev on Sun Mar 01 2015, 19:25
Hi gobble
Wire wool will not scratch brass I have always used it for first clean to remove tarnish. If you check out the new projects section r2 X 2 the brass on that engine was really cruddy and the finish you see there was off wire wheel on a drill brass is a lot harder than you think.
Post by woody on Mon Mar 02 2015, 12:00
kev wrote:Hi gobble
Wire wool will not scratch brass.
Depends how hard the wire wool is. Different makes = different hardnesses.
I suggest you try the wool on a part of the cover that doesn't show.
To old to die young
woody
Post by callum12 on Fri Mar 06 2015, 22:51
wait until its running then using scotch pads to clean it up. scotch is much less aggressive that wire wool. and since the engine is running the scratches left run in the same direction as the grooves and won't be noticed.
hope this helps and be carful!
callum
callum12
Post by Gubble1234 on Sun Mar 08 2015, 21:50
When I get home at easter, I'll give it a go and put some pictures of the results on.
Thanks for all the replies!
Gubble1234
