Petter A1 Project
+6
jakesdad13
Locknut
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Petter A1 Project
Woodsman wrote:Thanks Pete - Saturday, Sunday or both ?
Saturday, Sunday and Monday I was told by a chap at our club event last weekend.
Yes mate its all three days, I won,t be staying over as I haven,t got a towbar fitted to the van yet so I can,t pull the caravan, but if you come over look for the rusty old banger merc sprinter with lots of grey primer that will be me then!!
jakesdad13- Born to be wild
As our Villiers MK20 HS project seems about to hit the buffers we thought we might try the air filter on the Petter A1. Okay, it's a bit of Frankenstein job but we reckon it looks something like. What do you think?
You have done well with the restoration, a cracking job there fella.
Petter77- I really need to post more
Thanks. Sadly it will have to go to auction shortly as I keep tripping over it whilst working on new projects.
The idea with shorting out the high tension, or rather not operating the mag when the secondary is open circuit, is that with no "load" the secondary voltage can get extremely high if it is not absorbed in a spark or short, so high that it can break down the coil insulation and in for practical purposes destroy the coil.
BTW air (even with fuel in it), at high pressure has much higher resistance than at atmospheric, hence some old spark plugs break down at high throttle (when compression is higher, therefore spark voltage is higher), even though they appear to test OK at atmospheric, and cause misfire when you try to load the engine or open the throttle much.
Darryl Ovens- Expert
I'm not even allowed to quote a post with a link in
Have you an up to date link for a Gib puller please Paul?
Andywaters- Life Member
Andywaters wrote:I'm not even allowed to quote a post with a link in
You can make your own like I did - https://ukengineforum.forumotion.com/t9465-gib-key-extractor
or buy one from Ebay - https://www.ebay.co.uk/itm/182963279071
Both types work fine
That type wont work on the belt drum of the one I've bought unfortunately but thank you.
Sorry I cannot post a picture yet
I think your DIY one would be too big also to fit inside the drum.
EDIT that Wolsley WD2 you sold was a thing of beauty
What about this type - bit pricey mind.
https://www.ebay.co.uk/itm/254428686203
Second thought. I think I still have mine somewhere and unlikely to get another A1 - will check tomorrow.
Last edited by Woodsman on Thu Sep 16 2021, 16:16; edited 2 times in total (Reason for editing : additional)
Yes that's what I need but on top of that price from India will be duty and VAT so just not worth it.
I've seen one fella use a slide hammer with a hook on the end.
Last edited by Woodsman on Fri Sep 17 2021, 16:49; edited 2 times in total (Reason for editing : typo)
Thanks Paul. I'll let you know when I get it home tomorrow.
Page 2 of 2 • 1, 2
» My Petter a1 project
» New Project Petter A1
» First project (Petter A11)
» Petter A1 restoration project
» First attempt project
Page 2 of 2
