lister d carb problems
Post by lister d on Mon Mar 30 2015, 12:00
hi all engine wll start and then just cut out or keep running fine what could this be ??? my mate callum seid that I could be the carb but i dont no for sure iv rebuild the carb 3 times and nothing has work
lister d
Re: lister d carb problems
Post by 200TDi on Tue Mar 31 2015, 12:21
how good is the spark? if weak that could be your problem especially if the condenser is old and possibly breaking down
1999 Land Rover TD5 Discovery (previously 2x 1993 200TDi Discovery's and a 1965 Series 2a)
Coborn C3 - serial no 20127 - age thought to be around 1947/8.
Lister D Sheep Shearing Set - The D is Serial No 1/65855 (1951) so assume the s/set is the same age.
Petter A1 V/O 3hp@1500rpm - Serial 538215
200TDi
Post by Woodsman on Tue Mar 31 2015, 12:43
My two pennyworth is look at ignition. Could be an intermittent short/break?
Post by billypurves on Tue Mar 31 2015, 20:22
Lister D carbs are bullet proof. I agree with the others look to your magneto. Billy.
billypurves
