lister d carb problems
hi all engine wll start and then just cut out or keep running fine what could this be ??? my mate callum seid that I could be the carb but i dont no for sure iv rebuild the carb 3 times and nothing has work
lister d- Posts : 2
Re: lister d carb problems
how good is the spark? if weak that could be your problem especially if the condenser is old and possibly breaking down
1999 Land Rover TD5 Discovery (previously 2x 1993 200TDi Discovery's and a 1965 Series 2a)
Coborn C3 - serial no 20127 - age thought to be around 1947/8.
Lister D Sheep Shearing Set - The D is Serial No 1/65855 (1951) so assume the s/set is the same age.
Petter A1 V/O 3hp@1500rpm - Serial 538215
200TDi- Born to be wild
My two pennyworth is look at ignition. Could be an intermittent short/break?
Lister D carbs are bullet proof. I agree with the others look to your magneto. Billy.
» Lister D - Carb Problems
» Lister D carb problems.
» Lister D carb
» Lister D carb setup
» Lister D - Starting Problems
» Lister D carb
