1924 wade drag saw.
Page 2 of 2 Previous  1, 2
Re: 1924 wade drag saw.
Post by StewartH on Fri Jun 26 2015, 11:30
and a pdf of the manual here...
http://rmwade150.com/pdfs/drag_saw_manual.pdf
StewartH
Post by earlsinclare on Fri Jun 26 2015, 19:22
thanks for the info Hamish,
the articles in the American magazine are interesting. the people at wade in America have been very helpful with manuals, history and are currently trying to make contact with someone who can help with the chain.
work is continuing on the cooling system, trying to connect the tank to the engine, unfortunately the mop bucket is the wrong shape to make connecting it easy.
still at least I have a mop bucket now. lol!
Richard...
earlsinclare
next job is to set the carb.
Post by earlsinclare on Sun Jun 28 2015, 12:15
the cooling bucket is now piped up, ( go away and come back tomorrow, and the answer is looking at you straight in the face scratch )
the trolley now has wheels, they are still in need on a coat of paint. next job is to connect the fuel tank and set up the carb.
Richard...
earlsinclare
fuel tank fitted
Post by earlsinclare on Mon Jun 29 2015, 19:25
hello everyone,
fitted the fuel tank today, still trying to decide if I like the position of it yet. the hunt for a chain has gone cold, no replies to my emails.
Richard...
earlsinclare
first run
Post by earlsinclare on Sat Jul 04 2015, 12:20
hello everyone,
I connected the fuel tank up to the engine today, started it running messed with the timing and it ran well for 5 minutes if a little loud (no silencer) then turned it off, don't want to annoy the neighbours. next jobs are to make a silencer and add some weight to the front of the trolley to stop it moving around.
Richard...
earlsinclare
done a bit more.
Post by earlsinclare on Thu Jul 23 2015, 06:17
hello,
I,ve been doing a bit more on the wade, fitted a ballast resistor to the ignition system and played about with the timing to get it running slower. still got to do the silencer and fix a leaky fuel mixer. the cooling tanks needs to be bigger. so still plenty to do over the rest of the summer.
still looking for a chain.
Richard...
earlsinclare
Post by Gubble1234 on Fri Jul 24 2015, 18:15
I was browsing eBay this evening, and I found this:
http://www.ebay.co.uk/itm/Stationary-engine-dragsaw-/191641779164?pt=LH_DefaultDomain_3&hash=item2c9ebd7bdc
I immediately recognised it and thought maybe you could contact the owner for information about parts like the chain if you needed to.
Just thought I'd point it out to you! Smile
Thanks,
Gubble1234
Post by earlsinclare on Fri Jul 24 2015, 19:54
thanks for the info. I have sent him an email.
Richard...
earlsinclare
Post by Darryl Ovens on Wed Jul 29 2015, 02:39
For the first few runs they often generate a lot more heat.  Then as they free up there is less friction (=heat), and less power required to overcome the friction.
I've been fooled on two occasions by this and enlarged the cooling capacity only to end up reinstating my initial cooling set up in order to get them to run hot enough!
Darryl
Darryl Ovens
back to work
Post by earlsinclare on Fri Sep 18 2015, 06:11
now that the summer is coming to an end, thoughts are turning to the wade drag saw that is sat in the shed. I still have several jobs to do, including a better cooling tank (it needs to be heavier). I just have one more outing this year nymr at goathland in October, so plenty of time to play.
Richard...
earlsinclare
improved cooling tank
Post by earlsinclare on Sun Sep 27 2015, 17:33
hello everyone,
I spent the afternoon working on an improved cooling tank. the old tank was not heavy enough and it let the water splash about too much.
this tank makes the end of the trolley heavier and stops the trolley walking about while the engine is running.
Richard...
earlsinclare
Post by earlsinclare on Sat Oct 03 2015, 16:40
a short video of it running.
https://youtu.be/h7r3Qi9D5wo
Richard...
earlsinclare
Post by Woodsman on Mon Oct 12 2015, 08:39
Hi Richard,
You mention '..nymr at goathland in October' - could you give us some more details please.
Post by earlsinclare on Tue Oct 13 2015, 06:06
earlsinclare
Post by Woodsman on Tue Oct 13 2015, 08:28
Thanks Richard, been there a few times to catch the steam train to Whitby but didn't realise there were IC engines to be seen.
