Petter A1 - Firing Problems
Post by Ally's_Engines on Thu Apr 16 2015, 10:47
I am making some improvements to my Petter A1 before rally season. I re-ground the valves, and after a re-assembly I gave it a test run. It pops fine and dandy, but there seems to be smoke coming out of the choke hole in the carb every time it starts. Do you think I have messed the tappet clearances when I was valve-grinding? Have I not ground the inlet valve enough? Any help is much appreciated.
Cheers,
Ally
Ally's_Engines
Re: Petter A1 - Firing Problems
Post by Woodsman on Thu Apr 16 2015, 15:42
Hi Ally,
Tappet clearance should be 10 thou. Our newly acquired A1 was way out when we checked. If you have a nice matt line around valve and seat you should be fine.
I would have thought that lapping the valves would effectively lengthen the valve stem since the valves would be sitting lower in the seat. So the tappet clearance would be reduced and the inlet might open a little early. Best to check as it's an easy adjustment to make.
Post by Ally's_Engines on Fri Apr 17 2015, 10:21
Hi Paul
I checked the clearance and it is at 10 thou on the dot. I'm just going to give her a long run and see if that makes any difference. Thanks for your help...
Regards,
Ally
Ally's_Engines
Post by Woodsman on Sat Apr 18 2015, 09:55
Hi Ally,
Can you feel it blowing from the carb on the compression stroke if you put you hand over the inlet? That might indicate that the inlet valve is not seating properly.
You could also check the gasket - maybe it's leaking across from exhaust port?
Post by Ally's_Engines on Sun Apr 19 2015, 14:14
I'll give that a try thanks Smile
Ally
Ally's_Engines
