Villiers popping through exhaust.
Post by rich07961 on Sun Apr 19 2015, 16:59
Hi all,
I have a problem with 3 of my villiers engines now 2 x Mk 20 and Mk 12
I am getting a miss fire popping sound back through exhaust almost like a small backfire,
I have used different carbs, the valves have all been ground in and gaps checked, have checked
and double checked but no difference, any ideas that I could try, many thanks in anticipation.
rich07961
Re: Villiers popping through exhaust.
Post by Woodsman on Mon Apr 20 2015, 07:46
Timing, tappet clearance?
Post by kevjhnsn on Mon Apr 20 2015, 12:15
Woodsman wrote:Timing, tappet clearance?
o
timing should be 3/16" before tdc that is the piston not the flywheel,when piston is set 3/16" btdc set the flywheel timing marks to all line up
some will also for light work and displaying you can set all up to tdc but i dont go any less than 1/8" before tdc
i thinking its the timing as you will have done all of them and the flywheels are keyless and a sod to set up on your own
hope this helps
Post by rich07961 on Thu Apr 23 2015, 17:01
Thanks Kev and Paul,
It was the last part that I got wrong ref setting flywheel to mark at 3/16 btc, I read somewhere to set points to correct gap
then it was 3/16 just as the points open, then I thought the marks were there to time at tdc.
All good now, well one is no time to take cowls off others yet.
Thanks again
Regards Richard
rich07961
Post by rich07961 on Sat Apr 25 2015, 12:28
Now all running sweet, thanks again.
rich07961
Post by kevjhnsn on Sat Apr 25 2015, 12:59
your welcome and now a qualified villiers timing tecnition Wink
