BTH Magneto
BTH Magneto
Post by Ally's_Engines on Sat May 02 2015, 18:48
I have a BTH magneto belonging to a Douglas flat twin engine. It's producing no spark so where should I start? I've got a multi meter but I'm not very clued up with fixing magnetos. I was quoted as much as £250 just to send it to a workshop for a check up so I might as well give it a go at home.
Ally
Ally's_Engines
Re: BTH Magneto
Post by blue cat on Sun May 03 2015, 17:47
Ally, £250 is ridiculous Shocked Shop around...
Check out the magneto guys on another stationary engine forum, they are much cheaper.
Put your meter across the slip ring and the end of the shaft to measure resistance.
The Douglas stationary engine will not be worth more than the repaired magneto though, so only do this if you intend to keep and rally it.
cat
blue cat  cat
Re: BTH Magneto
Post by Ally's_Engines on Wed May 06 2015, 09:20
Thanks, I'll give them a try Smile
Ally's_Engines
Re: BTH Magneto
