Villiers MK20/25 Engine Oil
Post by chiefy on Fri May 15 2015, 10:06
Can anyone advise me about engine oil for these engines,my operating handbook advises below 16 faranhiet Castrol S.A.E 20, 16 to 90 degrees Castrol XL(S.A.E.30),do the oil grades of modern oils match these, or do they have addatives and do i need to stick to straight oils,any advice welcome.Chiefy.
chiefy
Re: Villiers MK20/25 Engine Oil
Post by Foden on Fri May 15 2015, 13:08
I run all my petrol engine's on Wilkinsons 20/50 and have never had a problem in 20 years. Other's will have different ideas though, straight 30 was what was generally used when most of 'our' engine's were new but times and oils change.
Post by chiefy on Tue May 19 2015, 09:38
Hi Pete,Thanks for your reply you say you use Wilkinsons 20/50,I presume you mean Wilkinsons Store,next time i go into Huddersfield I will go into their store and purchase some,thanks for that.Best Wishes Keith.
chiefy
Post by Woodsman on Sun May 24 2015, 15:55
Hi Pete,
Have a look at common or garden (apologies for the pun) lawnmower oil. There are plenty of SAE-30 equivalent around
http://www.amazon.co.uk/gp/product/B00E9573X4?*Version*=1&*entries*=0
Post by chiefy on Tue May 26 2015, 10:26
Hi, Woodsman thanks for engine oil info I have sourced oil from Wilkinsons, Thanks to Pete Foden, best regards ,Chiefy.
chiefy
