Crank case cleaning
Crank case cleaning
is there anyway of cleaning crankcases without making a complete mess, i did a D last year gunked it, then got the pressure washer in there, but what a mess, how do you do it
Re: Crank case cleaning
Wipe as much out as possible get your self a tin of carb cleaner spray that in there and keep wipeing.
If you still having problems get a blow lamp in there it go's all crispey then hover it out
Whe I did my D's Ryan I emptied them wiped out as much as possible, took them up to local garage sprayed with gunk cleaner and used the steam cleaner in the jet wash area.
They guy only charged me a couple of quid for using his steam cleaner.
Brought it up like new.
Took it home dried it off and left air heater on it for an hour.
Job done.
cheers
Job done.
cheers
BRASSO- Life Member
Wipe it all with Rags and soak it with Parrafin and keep wiping .
I usually suspend mine over a large bucket and use parrafin from a spray bottle with a paintbrush to get in the awkward areas .
There realy is no way of doing it without a mess
It does help if you can get the engine nice and hot before you drain the oil first though
Steve
Steve
Avandriver- Expert
ryan wrote:is there anyway of cleaning crankcases without making a complete mess, i did a D last year gunked it, then got the pressure washer in there, but what a mess, how do you do it
if you get in there with a low viscosity degreaser and spray it on with something like a wwhat do you call them...... spray bottles used fro detergent in the kitchen. then the degreaser will loosen the sludge and scale off, then rise it off with the said sprayer, using either diesel or parrafin, it wont get it all off, but it probably wont be overly messy, just let the degreaser do its thing, then make sure you get all of it out, or the next batch of oil may not last long! lol
» Crank Case Breather
» Lister diesel crank case filling with fuel
» wolseley goveners
» Petter A1 starting (or not in my case)
» Had a cleaning day :D
» wolseley goveners
