Ruston PB6 throtle problem
Post by RAB on Wed Aug 12 2015, 18:30
Hi all,
I'm trying to set up the throttle on my PB6, at present the throttle does not work on the screw, but take the cover of the crank shaft end and manually pull the lever and it works the throttle linkage. Adjust the throttle screw out and it locks the arm for the governor linkage, Any help will be greatly appreciated.
Dont learn tricks of the trade, learn the trade itself !!!!
Re: Ruston PB6 throtle problem
Post by billypurves on Thu Aug 13 2015, 20:12
Hi Paul, Have you set the end of the governor arm to the pin pushed out by the governor weights?
billypurves
Post by RAB on Thu Aug 13 2015, 20:23
Hi Billy
No, I haven't touched the adjustment yet, should there be a gap between the shaft and the arm?
Are you at Bigger at the weekend?
Post by billypurves on Fri Aug 14 2015, 06:55
There should be a gap, I usually set mine with the engine running to get the speed I want.......but be careful. You will not be able to do this with the Lucas mag anyway.
I think the gap should be around 3mm. Mine are set to just a gap and no more to slow them down a bit. Is this a Lucas Mag or a Villiers?
I have not booked for Biggar, but if the weather is decent I will come for a walk round and a blether. Rgds Bill.
billypurves
