Lister B drain cock
Lister B drain cock
Post by jakesdad13 on Wed Sep 02 2015, 12:13
Hi I am in the process of restoring a 1928 Lister B, I need a drain cock for the hopper doe,s any one know what size I should be looking for? also are the fasteners on the engine- nuts, bolts, studs etc a standard fitting, whitworth perhaps? and can any one tell me where I can get copper fuel piping from? Cheers, Pete.
jakesdad13
Re: Lister B drain cock
Post by blue cat on Wed Sep 02 2015, 12:39
Most of the standard threads on a Lister B are Whitworth.
The pipe threads and drain cock will be BSP.
Copper pipe is readily available at your local caravan shop.
Pipe nuts and nipples are available from vintage motor car suppliers on the web.
blue cat  cat
Lister B drain cock
Post by jakesdad13 on Wed Sep 02 2015, 12:47
Thanks Blue cat the copper pipe that caravan stores sell is to small for what I need but I will check out the classic car suppliers as I hadn,t thought of that, also Normous Newark is coming up shortly so I might get something there. Pete.
jakesdad13
Post by Woodsman on Wed Sep 02 2015, 15:11
I got 6mm (1/4") and 8mm (5/16") pipe and olives from my local DIY shop - they even cut me short lengths from a coil.
Post by blue cat on Wed Sep 02 2015, 19:43
jakesdad13 wrote:Thanks Blue cat the copper pipe that caravan stores sell is to small for what I need but I will check out the classic car suppliers as I hadn,t thought of that, also Normous Newark is coming up shortly so I might get something there. Pete.
Or you could try here:
https://www.vintagecarparts.co.uk/categories/vintage-car-parts-taps-pipe-and-fittings-fittings
Nipples and pipe nuts are about 2/3 down the page. They also supply copper pipe.
6mm is approximately 1/4" (not 1/2")
But, apart from convenience, why buy metric when the correct imperial fittings are available.
blue cat  cat
Post by Woodsman on Wed Sep 02 2015, 20:23
Oops typo!!,  if I had quoted 1/2",  then quite correct Blue cat.
I love a pedant except, of course, one who corrects my mistakes.  Smile
Having reviewed my post  - I wrote 1/4" NOT Half inch - back to you Blue cat Smile
Post by blue cat on Thu Sep 03 2015, 18:19
You are the one who has edited your original post (twice) so I'll let the facts speak for themselves. Smile
blue cat  cat
Post by Woodsman on Fri Sep 04 2015, 14:51
Did I ? Okay, I give in Wink
