Help WD problem.
Help WD problem.
Post by RAB on Sun Sep 06 2015, 16:12
Good afternoon all,
I have a problem with my WD2, I cant adjust the throttle when its running, can anyone help?
Dont learn tricks of the trade, learn the trade itself !!!!
Re: Help WD problem.
Post by billypurves on Sun Sep 06 2015, 20:16
When you say adjust the throttle is the adjustment to slow down?
billypurves
Post by RAB on Mon Sep 07 2015, 16:24
I cant adjust the engine speed at all Billy, with the adjuster
Post by Foden on Mon Sep 07 2015, 18:48
If the speed doesn't increase when you pull the control knob out against spring pressure then it has probably become disconnected somewhere. You may see something if you remove the tappet sideplate.
Post by billypurves on Mon Sep 07 2015, 22:45
When you open up the side plate you will see the bronze governor arm.Have a look at the bolt on the end of it, sounds to me the bolt is screwed in too far.
billypurves
