can anyone recommend a maker of seals
Re: can anyone recommend a maker of seals
ryan wrote:there is amos pumps in cornwall, but there a little expensive
What pump is it for Ryan?
I think Amos are the only ones down our way, but as you say are rather expensive.
What type of gaskets do you want to make?
cheers
BRASSO- Life Member
Ryan, try Premier Products in Plymouth, speak to Bill and tell him i sent you, he has never let me down on seals, bearings, belts, pullys etc and they are very reasonably priced
If you can give me sizes i will see what he can do if you don't have time
iansw- A credit to the forum
cheers chaps
its a seal for my climax, pump cant give to many details as im not sure myself :hysterical:
talking of seals
does anyone know where i can get wolseley wd2 seals from??????????
there like trying to find rocking horse sh**
can anyone help?????????????
many thanks mike.
many thanks mike.
ryan wrote:its a seal for my climax, pump cant give to many details as im not sure myself :hysterical:
Why not buy the material and make them yourself Ryan.
Thats what I did with my domestic pump, apart from the neoprene ones on the hopper.
cheers
BRASSO- Life Member
The lad who had it before me tried making one out of a truck mud flap, really wanna do it right if im going to do it , hopefully it will last then
Hi Ryan,
If it's a rubber type gasket then I believe it would be made from neoprene.
You should be able to buy this in sheet material.
I had a similiar problem getting gaskets for my H2 pump so I made one and used a piece of left over butyl pond liner. It really has worked a treat and has a 20 year life span (re breaking down).
Very similiar material to neoprene.
I still have some left if you would like to try some.
Last edited by MARTIN BRASSO HAMBLY on Thu Sep 17 2009, 08:37; edited 1 time in total (Reason for editing : miss spelling fingers again)
BRASSO- Life Member
» What Engine oil do you recommend for a lister "a" and "b" types
» Head Gasket Maker
» Pump seals.
» Seals for S12 carburettor
» Villiers lightweight oil seals.
» Head Gasket Maker
» Pump seals.
