winter project...but what is it?
Post by bigsja on Thu Nov 19 2015, 19:30
All I know at the moment is that it supposed to be a 1916 3hp open crank petrol/parrafin........manco?????
bigsja
I really need to post more
Re: winter project...but what is it?
Post by StewartH on Fri Nov 20 2015, 07:11
I know what it is.... Its brilliant!
But I cant help identify - I'm no specialist:) - Although it does look Amanco like...
Keep us informed - it looks great.
Best
Hamish
StewartH
Post by bigsja on Fri Nov 20 2015, 16:46
Hi Hamish...yup your are correct...amanco chore boy...in bits at the moment and primed awaiting painting but engine is complete except for a fuel tank which is in the process of being made...not a bad buy for £400.00....even got a good spark!
bigsja
Post by steve w on Fri Nov 20 2015, 18:35
nice engine and a bargian - strange to see it with the spark plug.
Post by tony old g on Sat Nov 21 2015, 12:06
Hi, Looks like a 3Hp Amanco petrol/ paraffin that has been converted to a hign tension magneto and spark plug.
very good buy. tony
tony old g
Post by fowlerfan on Sat Nov 28 2015, 15:51
Looks like a 3 Mule Team - Nice project for a good price.
Keith Smigle's site is very good   [You must be registered and logged in to see this link.]
If you click on the link 'Associated Photo Album' you will find all the models listed.
David Edgington's Amanco book is well worth a read, and if you ask nicely he may sign your copy...  [You must be registered and logged in to see this link.]
Dave
fowlerfan
http://www.stationaryenginesscotland.co.uk
Post by bigsja on Sun Nov 29 2015, 00:41
Thanks Dave...after a bit of a clean of the brass plate looks like you are right 3mules (for sister Sarah?) thanks for the links...it would appear that the spark plug/mag combo was to try and make starting easier in our slightly damper weather....all cleaned now and in bits ready for its coats of red...just waiting for better shed weather!
bigsja
3 mules plus helper
Post by bigsja on Sun Jan 10 2016, 12:34
[You must be registered and logged in to see this image.][im[You must be registered and logged in to see this image.]g][You must be registered and logged in to see this link.]
no fuel tank yet but one willing helper...started rebuild white paint is undercoat...timing to sort out next
bigsja
Post by Woodsman on Sun Jan 10 2016, 16:37
If you are stuck Franks Tanks might be worth a call...
