Climax No1 Water pump
Post by rich07961 on Mon Nov 30 2015, 10:33
I have been a bit quiet on here lately, but does not mean I have not been busy, picked up the Climax at Oakley a few weeks ago and glad it was all there, which when looking at most of these for sale have bits missing or frost damage, all I had to replace were the botched up bearings on the shafts and the leather cups that were perished, then a good clean up and paint, I have used the colour that the Bamford SV3 is going to be as I will use the SV 3 to run pump next year at rallies. I now need to sort out pipework and tank, I did think about using the water tank from the Bamford to feed pump and then back to tank, which I presume would keep engine well cool, what do peoples think,
rich07961
Re: Climax No1 Water pump
Post by StewartH on Mon Nov 30 2015, 10:42
Got to say I really like that colour - its lighter than all those heavy dark greens we tend to see - better for an engineers eyes to visually check - and it shows off the detail nicely!
Not sure what an optimal operating temperature is for a Bamford SV3 is but I'm thinking this pump may move a lot of water/ gallons/ litres per minute/ hour - might mean it takes your engine longer to warm up to prime operation temp but as its a rally engine not under much load who cares! - I don't think it will cause any mechanical issues or wear more at low speeds and loads.... perhaps a drip or more of oil but not enough to worry about...
Best
Hamish
StewartH
Post by Woodsman on Tue Dec 01 2015, 11:24
Lovely job. Smile
Post by rich07961 on Thu Dec 03 2015, 16:00
Have been studying pictures of these pumps and see there should be a belt guide, so decided to make one up this afternoon,
just need to get painted, also used stainless steel rod so won't have to worry about paint being rubbed away.
rich07961
