PE Battery charger made by A.C Morrison
+2
tony RA
6 posters
I have had this generator for about 18 months now and have finally started working on it. It had not been run for about five years before that. There is no spark when turning the motor over. Checking the points they seem fine, almost new. They measure short circuit when open if I put a multimeter acros them. Removing the condenser and that was fine but still short across the points. Removing those and they are fine. The coil primary measures zero ohms while the secondary measures approx 18 kohms. Can anyone tell if these are way off or normal? I suspect they are way off but when compared to a modern ignition coil not too bad. The motor is a Villiers 507-H1 magneto driven. Also anyone know what carb type is used in case I need to replace gaskets?
John C
John C
JohnC- Posts : 3
Re: PE Battery charger made by A.C Morrison
Hi John
Still a newbie, but I've never come across a Villiers 507-H1. Any chance you could post a picture?
Hi this sounds more like a Briggs & Stratton to me Paul but have been wrong plenty of times before
Hello
I am working on one of these sets just now. it has a Villiers B10/1 carburettor fitted.I found parts manual and service manual on free download somewhere on the net If that's any help,
reiver- I really need to post more
Secondary (HT) coil at 18K ohms is way too high. Should be about 4k ohms. Secondary is suspect (typical Villiers).
Hi, I thought the coil was faulty, mainly because the primary measures too low. I have looked at new replacements costing about £60, would that be about right or a bit pricey? Tried to upload images but I am not sure it worked.
JohnC- Posts : 3
You can get cheaper Taiwanese copies but you will have to solder on a copper shim.
http://www.classicbikeshop.co.uk/villers-coil-long-type.html
https://www.feked.com/electrical/ignition-system/ignition-coil/page-2/
or with copper pad
http://villiersservices.co.uk/index.php?main_page=product_info&cPath=8_18_52&products_id=28&enid=3vthbln4aphh6h0103ipqtc3j4
or with copper pad
pe battery charger
Have you tried Jon cruse at the mower centre hailsham? he can be reasonably priced for Villiers stuff
The primary winding is likely to be just a few ohms, which can be difficult to measure.
Try putting it in series with a 12v bulb, across a car battery, and measure the volts across the bulb and the volts across the bulb.
To old to die young
» Which lister diesel as a battery charger
» picture of p5X
» More Ignition Experiments
» my daughters first engine.
» Identification of Lister Engine
» picture of p5X
