Lister D top dead centre marks
Hi all, its me again. I have had the magneto on my engine checked by an engineer and its giving a good spark. My problem now is that I need to find out exactly where top dead centre is, and where the firing point is, as these have been obliterated due to it having stood out in the weather for some time before I got it.
Give me a clue please.
John
John
The Newby- Born to be wild
Re: Lister D top dead centre marks
When the piston is at the top of its stroke
The easy way to tell is when the flywheel keyway is at the bottom
The firing position is best at about 12degree before this position so if you set your crankshaft with the keyway at the bottom and then mark the top of the flywheel you will have a TDC mark.
Now rotate the flywheel ( in the direction its meant to go until the TDC mark is ABOUT 12deg before the top position. Now you set the mag so the points are just opening and lock up the bottom sprocket on its shaft.
Hope this helps.
Hope this helps.
ray fisher- Born to be wild
» Lister D top dead centre marks
» RH BPR 4HP Flywheel Timing Marks
» The Mower Centre
» Dead red diesel??
» Dead Petter
» The Mower Centre
» Dead red diesel??
» Dead Petter
