Lister D cylinder head skim.
Post by chris54-bikes on Wed Jan 27 2016, 11:50
Hi,  Does anyone know the maximum permissible skim you can do on a D head ?
In one corner of mine is a run-off and I can get a 6 thou feeler under it, its only in a small area and dos"nt look like its where anyone as damaged it in the past removing the head, its more like erosion  !!
If anyone"s any info would be nice  ?
cheers,  Chris. Question
ps,   its not in any areas around the piston bore and everywhere else is nice and flat.
chris54-bikes
Re: Lister D cylinder head skim.
Post by Villiers on Thu Jan 28 2016, 11:16
Head gasket should take that up ok. Use a proper composite gasket and it should be fine, if you do go down the skimming road then 6 thou should be enough.
