Villiers Coil
Villiers Coil
Post by chiefy on Wed Apr 13 2016, 09:35
HI i am on the lookout for a coil for Villiers magneto the MK20/MK25 model I see on E BAY there some offered these appear to be from the far east and do not have the button on top like the Villiers they appear to have a tab sticking up, as anyone used these coils and if so what was your thoughts on them. Chiefy.
chiefy
Re: Villiers Coil
Post by Woodsman on Wed Apr 13 2016, 16:22
I'm going to give one a try. Ordered mine here:
https://www.feked.com/electrical/ignition-system/ignition-coil/page-2/
You can get the proper job with the button but more than twice the price:
http://villiersservices.co.uk/index.php?main_page=product_info&cPath=8_18_52&products_id=28
Re: Villiers Coil
Post by chiefy on Thu Apr 14 2016, 10:10
Woodsman wrote:I'm going to give one a try. Ordered mine here:
Greetings Paul,Thanks for that how are you going to get round the coil not having a button on the barrel are you going to bend over the tab or will you solder a button onto the tab,I would be interested to hear your thoughts on the coil when you come to fix it on your engine. Best Regards Keith.
products_id=28
chiefy
Re: Villiers Coil
Post by Woodsman on Thu Apr 14 2016, 15:58
Have salvaged the button from the duff coil. Will post as I go.
Re: Villiers Coil
Post by chiefy on Fri Apr 15 2016, 09:51
Ok Paul,good idea to salvage the button of the duff coil, I will look out for your post to see how you go on fitting to your engine,thank you .Keith.
chiefy
Villiers Coil
Post by chiefy on Tue May 10 2016, 09:16
Greetings Paul, Did get your coil fitted and if so was it a success.Best Regards. Keith.
chiefy
Re: Villiers Coil
Post by Woodsman on Wed May 11 2016, 09:32
Hi Keith,
Sadly I've been laid up with a bad back. Feeling better now but going away for a couple of weeks so won't get chance to work on engines. Will post when I get back into the workshop.
Re: Villiers Coil
Post by chiefy on Fri May 13 2016, 10:19
Hi Paul, Sorry to hear about the bad back I do have bouts of bad back the last time it happened I had just had a shave and was rinsing my face when it went, enjoy your break. Best Wishes Keith.
chiefy
Re: Villiers Coil
Post by Woodsman on Thu Jun 23 2016, 10:21
OK - back in the workshop!
1) Solder fly lead to salvaged button..
2) Solder other end to HT terminal..
3) Stick button down with Gorilla glue..
4) Wrap with gummed tape to keep the dirt out..
Only issue I found was that the iron core was slightly smaller diameter than original so was a bit loose in the magneto cheeks. Just packed it out with some tape.
Now have nice fat spark  Smile
Villiers coil
Post by chiefy on Wed Jul 06 2016, 08:30
Hi Paul, Sounds like a successful outcome apart from the smaller core which you overcame with tape. Thanks for that Keith.
chiefy
Re: Villiers Coil
