Wolseley wd2 crank shaft oil seals
Post by pajman on Wed May 11 2016, 12:28
Hi.
Has anybody had issues with the crank shaft oil seals from stationary parts of york, here is my problem, they slide on the crank OK but when I try to fit them in the housing they won't fit unless you force them which makes the crank very tight to turn,if you do manage to start the engine the seals break up,the only thing I can think of is to boar out the the crank housings'is,this the only way?.
Thanks Ray.
pajman
Re: Wolseley wd2 crank shaft oil seals
Post by tony RA on Thu May 12 2016, 21:55
If you have to bore out or modify or remove metal from the casting the seals have to be wrong surely
tony RA
Post by pajman on Fri May 13 2016, 08:23
Hello.i have speaking to stationary parts of york and hopefully the problem with the wolseley seals will be resolved at tern valley rally in Aug when I meet up with a man that is an expert with these engine's.
Ray.
Last edited by pajman on Tue Jun 14 2016, 16:02; edited 1 time in total (Reason for editing : Apologises to stationary engine parts york.)
1954 wolseley wd2 better to move about for this old fellow Embarassed : Laughing Laughing Laughing
pajman
Post by blue cat on Sun May 15 2016, 17:59
Send a message to member "Foden" (Pete) on here, he'll be able to help you.
blue cat  cat
