Painting tips?
Painting tips?
Very soon I'll be beginning to paint my 1946 wolseley wd2. I was wondering whether anyone with some experience would give me a few tricks and tips, due to it being my first time working with enamel paint. Also how many layers should I use?
Oliver Ward- Born to be wild
Re: Painting tips?
I do 1 coat of red oxide, 2 of under coat and 2 or 3 top coats, before starting to paint I always spray everything with thinners to "kill" any oil or grease. Make sure your brush is good with no loose bristles, work area is clean and dust free and take your time.
Re: Painting tips?
Villiers wrote:I do 1 coat of red oxide, 2 of under coat and 2 or 3 top coats, before starting to paint I always spray everything with thinners to "kill" any oil or grease. Make sure your brush is good with no loose bristles, work area is clean and dust free and take your time.
OK thank you very much I almost forgot about undercoat
Cheers Oliver
Re: Painting tips?
preparation is the key to a good paint finish, the more time you spend on prep the better the results. always use the best quality paints/enamel you can afford and a good quality brush.
make sure the engine is clean of oil, grease etc. the flatter the base the better result you will get. as a rule of thumb what you see when you put the first coat of primer on is what you will see when you put on the top coat.
always paint in a warm dust free area and when you have finished close the door and don't be tempted to go and have a look, this will only stir up any dust and it WILL find its way onto your paintwork.
if you want to thin your paint don't use thinners place the tin in some warm water this will reduce the viscosity of the paint without diluting the colour.
hope this helps
Richard...
hope this helps
Richard...
earlsinclare- Life Member
Re: Painting tips?
earlsinclare wrote:preparation is the key to a good paint finish, the more time you spend on prep the better the results. always use the best quality paints/enamel you can afford and a good quality brush.
hope this whelps
Richard...
OK that's very useful to know
Cheers oliver
» top tips for trolley building
» Tips for bringing up brass
» sanding and painting
» letter painting
» Benco vacuumpump overhauling update 03072015 dating the pump. Yes it's very old!
» letter painting
