Jap 2A fuel pipes help
Post by iangt on Mon Jun 13 2016, 17:23
Hello,
I am currently rebuilding a Jap 2A as my first restoration. I have nearly got all the bits together and am only missing fuel pipes and connectors.
The fuel tank has a working fuel tap with a thread at the end. The Zenith type 13 carb is missing a fuel connector of some sort.
Does anyone know or can give some clues about what I need to get my engine finished.
I will try and attach some photos.
Thanks for your help everyone.
iangt
Re: Jap 2A fuel pipes help
Post by Woodsman on Tue Jun 14 2016, 08:09
You could try here:
http://www.vintagemotorspares.com/
Select Miscellaneous from the left hand sidebar and then scroll to the bottom
Good luck.
Post by kev on Sun Jun 19 2016, 19:01
Hi iangt .
I have a jap 2a for spares or repair . It has the same full tap as yours I has a lenth of clear fuel pipe attached but it is age and fuel hardened, the other end should be attached to a brass pipe on the bottom of the carburettor. If it's of any use let me know. Regards Kev
Post by blue cat on Mon Jun 20 2016, 11:42
text removed
blue cat  cat
Post by iangt on Wed Aug 10 2016, 10:54
Thanks for those replies. I have since acquired a pipe and banjos.
iangt
