Small flywheel for Lister D
Post by HobbyPaul on Mon Jun 20 2016, 17:55
I have a Lister D that looks like it originally had the shaft cut flush... however the main flywheel has three holes that could possibly have another pulley bolted to it....
the question is what other flywheels could possibly fit.
Pic to follow later.
HobbyPaul
Re: Small flywheel for Lister D
Post by StewartH on Tue Jun 21 2016, 15:44
Hi Paul,
Are these holes drilled smooth or are they threaded? - I've seen after market additions for couplers with smooth holes - where all sorts of equipment was run from prop shafts to pulleys for farm equipment, pumps and even gensets - however I've not seen holes that are threaded - but it would only lean to a better quality aftermarket solution... as you know the possibilities are endless.
Never did work out if they were made in the factory or not... Lets hope someone else has better experience of them...
Best
Hamish
StewartH
Post by slew53 on Tue Jun 21 2016, 20:08
I cannot tell you if there are other pulleys that will fit but mine has a three bolt fixing that mounts a Vee pulley on the inside of the flywheel.
Steve.
slew53
