Amanco threads
Amanco threads
Post by kev on Sun Jun 26 2016, 16:28
Hi all just started to put together my hired man and need to make a few studs I had thought I'd got all the bits sorted and in the back of my mind I think I thought they were whitworth threads but no. Can anyone tell me the thread type please.
Re: Amanco threads
Post by Woodsman on Mon Jun 27 2016, 11:10
Quote from this article..
http://www.gasenginemagazine.com/gas-engines/restoring-an-amanco-4-hp-hired-man.aspx?PageId=3#ArticleContent
"The cylinder head and igniter studs were very rusty, and were therefore removed, but two broke off making it necessary to drill them out. Not possessing the correct American dies, I decided to use Whitworth tap and dies that are virtually identical apart from the thread form. "
So maybe UNC- same pitch but 55 deg rather than 60 deg and flat crests rather than rounded.
Re: Amanco threads
Post by blue cat on Mon Jun 27 2016, 20:17
Yes, originally ANC (American National Coarse), now replaced with UNC  (Unified National Coarse), so UNC is correct.
Don't be tempted to change it to Whitworth as the pitch and TPI is also different in some sizes.
UNC taps/dies/nuts/bolts are widely available.
blue cat  cat
Re: Amanco threads
Post by kev on Tue Jun 28 2016, 00:16
Many thanks gentlemen I checked the studs that were already fitted and they were whitworth so Paul was crrect to a point but the fit was very poor so I'll take blue cats advice and get some taps and dies to make up my own studs cheers kev
Re: Amanco threads
Post by steve w on Sat Sep 10 2016, 14:41
Is this the Amanco you started a few yrs ago? i have not been on for a while, i see alot of the old names no longer come on much like Mat86, stationary stu, abes, nutgone, hope you are well Kev.
Re: Amanco threads
Post by kev on Sat Sep 10 2016, 18:27
It is the same engine. I had to put it to one side due to too many commitments and not enough playtime , at last I've been able to clear some free time and I hope to get it running to show next season. I've got the cylinder and block up to primer I've done most of the machining on the head (but just found the inlet valve is too short) and the trolley is cut to size and I hope to weld it up in the coming week. The only good thing about winter coming is that I might get a little more time in the shed just so long as she who must be obeyed doest find more for me to do.
Re: Amanco threads
Post by steve w on Tue Sep 13 2016, 00:59
will be good to see it running after all the hard work you have done to save it, cant believe winter will be here again soon, i seem to of missed another summer working.
Re: Amanco threads
