Seized? Lister D
Seized? Lister D
Post by kennill on Tue Jul 19 2016, 11:13
I have two D's
I have struggled to get one going but a carburettor strip and reset led to it running well on Sunday.
I ran it for a few minutes and shut it down normally.
When I came to restart it later on it appears to have locked.
There is a minute amount of play only on the flywheel, other than that it is solid.
I cannot understand how this can be.
Any ideas welcome, please?
(Removing the plug does not help one bit.
Ken
kennill
I really need to post more
Re: Seized? Lister D
Post by astrocreep2000 on Tue Jul 19 2016, 13:44
You could check to see if the magneto is seized. If it is , the chain would stop the engine from turning but give you a little bit of play on the flywheel. I had this problem with an early shaft driven D.
astrocreep2000
