Soldering fuel pipes.
Post by iangt on Wed Aug 10 2016, 10:56
I need to change fuel connections on a fuel pipe. However, I don't have/can't afford/don't have the skills to solder fuel pipes.
Any ways I can get round this would be appreciated! What trades could help me out? Would a local garage be able to do this for me?
Thanks
iangt
Re: Soldering fuel pipes.
Post by casper on Wed Aug 10 2016, 12:31
iangt wrote:I need to change fuel connections on a fuel pipe. However, I don't have/can't afford/don't have the skills to solder fuel pipes.
Thanks
Could you use a compression fitting instead?
Get an after life..
casper
Post by Mike Unwin on Wed Aug 10 2016, 13:27
I know what you mean about buying more tools that might not get used a whole lot but all that you would need is a small propane torch a bit of new solder and some flux. That might prove cheaper than paying or trading some one to do it because you might find another job for the torch .Cheers and good luck Mike
Mike Unwin
Post by iangt on Thu Aug 11 2016, 10:21
thanks both. I am a real newbie, got to ask what a compression fitting is?
iangt
Post by Mike Unwin on Thu Aug 11 2016, 12:52
It would a mechanical type joint just basically a nut on the fuel line pressing against a little brass collar to form a seal. Good luck Mike
Mike Unwin
Post by Woodsman on Thu Aug 11 2016, 15:18
You could try here:
http://www.vintagemotorspares.com/
Select Miscellaneous from the left hand sidebar and then scroll to the bottom
Good luck.
