Bunsen Burner
Bunsen Burner
Post by chiefy on Thu Sep 29 2016, 10:05
Hi Guys & Girls, I have a Hot air Engine it used to run off Town gas running a small bunsen burner, i would like to run this off Propane/Butane mix 500 ml canisters these are Coleman brand does anyone know where i can purchase a burner that will screw into the canister. Chiefy.
chiefy
Re: Bunsen Burner
Post by Villiers on Thu Sep 29 2016, 14:36
Screwfix. Toolstation, ebay....
Re: Bunsen Burner
Post by chiefy on Fri Sep 30 2016, 13:07
Hi Villiers, I had seen the burners at Screwfix already these are the ones i use for soldering and are bent i wanted one that stands vertical and screws to a small gas canister, i have seen some like these which stand independantly and are connected to larger bottle by a pipe i may have to use one of these,Thanks for that. Best Regards Chiefy.
chiefy
Re: Bunsen Burner
Post by Villiers on Fri Sep 30 2016, 13:18
Go to a plumbers merchants, Rothy do an adapter that fits on the gas bottle so a hose can be attached.
Re: Bunsen Burner
Post by Woodsman on Fri Sep 30 2016, 14:26
Why not try a camping / outdoor shop?
Re: Bunsen Burner
Post by chiefy on Tue Oct 04 2016, 13:46
Thanks Villiers,I have never heard of Rothy i will check them out .Thanks Chiefy.
chiefy
Re: Bunsen Burner
Post by chiefy on Tue Oct 04 2016, 13:53
Greetings Woodsman, I have looked at a couple of camping and outdoor sites they do have burners for cooking and lighting, but i have not seen any bunsen type burners,i have seen several free standing with a connection for a pipe from a larger bottle as Villiers says, i may finish up going down this route.
chiefy
Re: Bunsen Burner
Post by Woodsman on Tue Oct 04 2016, 15:13
Hi Chiefy,
Plenty on Amazon or you could try here;
http://www.coleparmer.co.uk/Category/Burners/57130
Alternatively, have a look in a fancy cookware shop. You can get re-fillable burners for use with vacuum coffee makers.
Re: Bunsen Burner
Post by chiefy on Wed Oct 05 2016, 11:47
Hi Woodsman, I have just found a camping gas lantern in a drawer in my workshop, it must be 25 years old it is a EPI gas these are no longer available,it is on a butane/propane mix 250 ml canister i believe that Coleman canisters are the same screw fixing,i shall try to remove the mantle and glass bowl to see if this will do the trick, never chuck anything away that may be useful!!!,i feel like it may be my birthday. Chiefy.
chiefy
Re: Bunsen Burner
Post by Woodsman on Thu Oct 06 2016, 08:49
Hi Chiefy,
You have just reminded me that, as well as a lantern,  there may be a single burner Campinggaz stove lurking in a dusty corner of my shop. Will have a search around today.
Re: Bunsen Burner
Post by Woodsman on Thu Oct 06 2016, 15:30
Hi Chiefy,
Could you make this do the job?
It's a Camping Gaz Bluet S 200 which uses a non-refillable pierceable canister which seem to be still available.
Here's a youbend video of how to change the canister.
https://www.youtube.com/watch?v=4h4kbK1BdTo
Re: Bunsen Burner
Post by chiefy on Fri Oct 07 2016, 09:08
Hi Woodsman seen your stove it looks like it would run a hot air engine ok. Best Regards Chiefy.
chiefy
Re: Bunsen Burner
Post by Woodsman on Fri Oct 07 2016, 15:00
It's yours FOC if you'll cover the postage. PM me if interested.
Re: Bunsen Burner
