Lister D push rod rod
Post by Mike Unwin on Wed Dec 07 2016, 21:30
Good day,
I am looking for a push rod for a early shaft drive Lister D it is about 10.75 " overall length , the later ones are 10.5 " and are too short if you have one for sale I would be interested .One would get me running . I am sorry for the confusion got mixed up with a measurement .Thanks Mike
Mike Unwin
Re: Lister D push rod rod
Post by Villiers on Wed Dec 07 2016, 21:39
I'm sure 0.5mm isn't that much of an issue.....
Post by Mike Unwin on Wed Dec 07 2016, 21:42
It is almost a 1/4 of a inch even with the screw turned all the way in the gap is far too much .Cheers Mike
Mike Unwin
Post by Villiers on Thu Dec 08 2016, 07:10
I did wonder if you left a "0" off...
Post by rich07961 on Fri Dec 09 2016, 14:52
Hi mike, you could always make up the different by using a valve cap, as I believe the early ones did not have them.
rich07961
Post by Mike Unwin on Fri Dec 09 2016, 21:33
Thanks Richard I did some research and found some people with performance engines actually make their own push rods,I think I have a simple fix I put the lock nut under the rocker and the screw now adjust okay. Thanks the list of things to do is just that much shorter .Cheers Mike
Mike Unwin
