Sealing of fuel tanks.
Post by RAB on Sat Dec 31 2016, 18:12
Hi all,
What do you use for sealing a fuel tank? I've a tank with pin prick holes in it and I just want to seal it without welding it up.
Dont learn tricks of the trade, learn the trade itself !!!!
Re: Sealing of fuel tanks.
Post by 1945ruston on Sat Dec 31 2016, 20:50
I've used Petropatch putty or the liquid version a couple of times and found it to be quite successful
1945ruston
I really need to post more
Post by rich07961 on Sat Dec 31 2016, 21:18
Hi Rab, have used POR 15 fuel tank sealer on quite a few tanks you can get as a kit, just need to follow the instructions to the letter.
Regards Richard
rich07961
Post by RAB on Sun Jan 01 2017, 21:48
Thanks for that guys, I've got 3 tanks to seal so that's great.
Post by fowlerfan on Sun Jan 15 2017, 15:34
FROST do a good kit for motorbikes that usually does a few stationary engine tanks. Preparation is key with this stuff and getting the tank absolutely dry after rinsing is a must. Cheers Dave
fowlerfan
http://www.stationaryenginesscotland.co.uk
Post by RAB on Tue Jan 17 2017, 22:33
Thanks to all for there help, will let you know how I get on.
Post by Locknut on Wed Jan 18 2017, 08:27
Hi Paul,
I have used Petropatch - a kind of putty stuff - very successfully.I have also soldered small holes with success.As with all this preparation is key ie making sure that the surfaces are clean and grease/oil free.
All the best,
Kev.
Locknut
