Testing a condensor
Testing a condensor
Post by RAB on Sun Jan 01 2017, 22:45
Hi all,
Is there any way i can test a condensor with a normal run of the mill multimeter?
Many thanks
Dont learn tricks of the trade, learn the trade itself !!!!
Re: Testing a condensor
Post by Woodsman on Mon Jan 02 2017, 16:27
I believe there are a few post on this subject but here's my two penn’orth.
Set meter to resistance and select a high range. Connect probes to body and fly lead. The resistance should read low to start with and then climb as the battery in the meter charges the condenser. Easier with old school analogue meter but does work with digital. If possible, practice with a known good condenser first so you can see what happens
