4.5hp Bradford Amanco engine
Post by steamman on Wed Jan 11 2017, 16:40
Hi, I am back again with a problem with my 4.5hp Bradford Amanco engine, I have had the head off and removed a lot of carbon, ground the valves in and skimmed the needle valves in the carb. which were out of round, I reassembled the engine and fired it up, it started easily but ran like a hit and miss engine, I noticed that the inlet valve didn't have a lot of movement on it, it just seemed to vibrate, could somebody give me some advice please as I am at a loss to know what to do next.
Thanks, Bernard
steamman
Re: 4.5hp Bradford Amanco engine
Post by emu15 on Tue Jan 17 2017, 20:18
Hi Bernard,i'm no expert but it seems kind of like the cylinder isn't getting enough fuel or something.I have heard of people saying that the valve springs on their engines were too strong so the valves couldn't open enough.This might not be the case with your engine though.Another thing that would stop the valve from opening enough could be that the engine hasn't enough compression so the valve couldn't pull the intake valve in enough.Just something to keep in mind.Regards,Eamonn
emu15
Post by Villiers on Tue Jan 17 2017, 23:19
Try running it faster.
Post by emu15 on Wed Jan 18 2017, 16:37
Another problem could be timing
emu15
Post by steamman on Mon Jan 23 2017, 15:02
Hi, thanks for all your advice, I increased the speed of the engine and it has cured the problem.
Bernaed.
steamman
Post by Villiers on Mon Jan 23 2017, 15:09
Thought that might be the case.
