BAMFORD 4HP OPEN CRANK
Post by emu15 on Fri Jan 13 2017, 21:53
Hello guys,recently got myself a bamford 4hp open crank.Will need a lot of parts as i got it in pieces.Will have some fun getting this thing together Very Happy I am wondering where would be the best place to get parts?My situation is that i got the engine disassembled and i have found some parts which i have no idea where they go Laughing I will try to keep you guys posted and will hopefully be able to send pictures.I am fairly new to this stuff so any help would be greatly appreciated!!!        Eamonn
emu15
Re: BAMFORD 4HP OPEN CRANK
Post by emu15 on Sat Jan 14 2017, 12:42
Can anyone tell me the best place to find a manual for this type of engine?I will need it for timing and to find where some parts go.        thanks. Eamonn
emu15
Post by rich07961 on Sat Jan 14 2017, 15:30
Hi Eamonn, send an email to here     http://henrybamfordandsonsuttoxeterengland.co.uk/museum-update/    and they have them for sale I think £ 19.99. or if you join The internal Fire Museum they Only charge a few pounds for one, this am not sure of you may be able to join a get a download, I have heard that its 40 pages long though. Regards Richard
rich07961
Post by emu15 on Sat Jan 14 2017, 20:23
Thanks Richard,I visited the Henrybamfordandsons site and found that they sell parts as well.Would they have many parts for my engine do you think?
Regards Eamonn
emu15
Post by rich07961 on Sat Jan 14 2017, 20:35
Hi Eamonn, if you send them an email with the serial no they will tell you who it was supplied to and year, send them a list of parts you might need and see as they have parts that they do not advertise, they are not the quickest in getting back to you but they are very informative as I found with my SV3 and of course look on the usual selling sites you never know. Regards Richard
rich07961
Post by emu15 on Sat Jan 14 2017, 21:07
Thanks a lot Richard,I'll email them and see what they have.Hopefully they will have a few parts that i need.I have an idea of the years they were made but unfortunately,i have no engine numbers because the plate which is situated on top of the water hopper with the model number was gone.Would i still be able to get it dated by parts numbers? Regards,Eamonn
emu15
Post by rich07961 on Sat Jan 14 2017, 22:17
Hi, as the plate is missing I doubt if they would be able to help, on the later Bamfords the serial no was stamped on the face end of the crank shaft, I do not know if that would apply to yours but worth a look, they would also advise where else to look, maybe someone on here might know.You may need to gently sand any rust off the end in case its very faint. Regards
rich07961
Post by emu15 on Mon Jan 16 2017, 08:21
Hi Richard,I tried looking on the face end of the crankshaft but there were no numbers.I do have the patent number though. I don't know if they could do anything with it though.regards Eamonn
emu15
Post by emu15 on Tue Jan 17 2017, 19:16
Does anyone have an idea of where these parts go?I have been searching on the web and can't see where they should go.
thanks Eamonn
emu15
Post by emu15 on Tue Jan 17 2017, 19:28
The exhaust valve is stuck solid.I have filled the area with diesel to try to loosen it but i haven't seen much change.I will have to figure out a way to free it without breaking the cast block.Also the sleeve that the valve slides through is broken off so it is going to be hard to get off.I was also wondering if the whole valve seat comes out because there is a large hollow nut component that threads on which you can see in the picture.
emu15
Post by emu15 on Tue Jan 17 2017, 19:31
As you can see in the picture the carb is badly rusted so i'm not sure if i will have to get a new one.
emu15
Post by emu15 on Tue Jan 17 2017, 19:34
The magneto is in very bad shape so most likely i will have to replace it.
emu15
