How to upload images
NOTE.
First.
There is, currently, no limit to number of images you can upload but please bear in mind that adding a lot of images increases the bandwidth required to display the posts. I would not like to incur the costs of an upgrade to the 'pro' edition. Please try to keep your images relevant to the topic under discussion. Many thanks
Second.
Editing posts to include links, images, videos etc is much more easily done in the desktop version of the site so I would recommend using that. Mobile version is fine for plain text.
1. Click Host an image.
2. Log in to the servimg server using the same email address and password as you have on this forum.
3. Click Select files. Note the option to resize - modern mobile phones take large pictures which may not display fully.
4. Browse your device and select up to three files and click open.
5. Click Send all. Be patient - it can take a few seconds and clicking repeatedly may result in multiple images.
6. When it appears click Insert all.
7. You are returned to your post with the links inserted.
8. Continue editing or click preview to check before sending.
9. Alternatively you can log in directly to the servimg web site ( [You must be registered and logged in to see this link.] )and select an image.
10. Then scroll down to see the links tab.
11. In the BBCode section click on either the thumbnail or image link then right click and Copy.
12. Return to your post and right click and Paste.
Hope this helps.
NB servimg.com does what it says on the tin - still images only. If you want to post video you will need to use a video hosting service such as Daily Motion, YouTube, Streamable and so on. Sorry - I can't help with setting these up.
First.
Second.
Hope this helps.
Last edited by Woodsman on Wed Sep 01 2021, 17:06; edited 3 times in total (Reason for editing : typo)
