Removing pulley wheel from fly wheel
Re: Removing pulley wheel from fly wheel
As far as I'm aware the pulley was never mounted like that by Listers, it would have been mounted on the shaft. The pulley is aluminium and will expand quicker than the cast flywheel, heat the pullet around the bossand it might give a little, get a stout length of rope with a loop on one end, put around the pulley and pass the other end through the loop and tie off on a bench then turn the flywheel in the other direction so the loop tightens and grips the pulley, it might break free, the aluminium and steel have coroded together.
Thanks for the advice. Pulley wheel now safely removed. Gentle leverage moving around the rim little by little did it.
» Removing a pulley
» Jap 2a removing points cam
» Removing a JAP 2A flywheel
» my lister shearer project
» Villiers Mk20 4 Stroke, how do I get the pull start pulley and rotor off ?
