Will it prime?
+3
maryalice
Robotstar5
7 posters
Re: Will it prime?
I reckon that as long as the water level in the tank is higher than the inlet it should syphon over nicely.
Re: Will it prime?
Nope, it'll air lock. See my reply on faceache.
Re: Will it prime?
Appletop wrote:Nope, it'll air lock. See my reply on faceache.
I stand corrected. Of course, bottom of pipe in bucket would need to be higher than pump to start siphoning
Re: Will it prime?
I did very similar with my A2 Godwin and that was a total pig to prime and very often ran all day on one side of the stroke and not both as they are a double acting pump, having said that it has worked that way for 30 odd years and I've still not changed it!!
Re: Will it prime?
Looks like I will be going for bottom entry (ooh err missus ) just got to find the plumbing equivalent of what I know as a bulkhead fitting.
Re: Will it prime?
Robotstar5 wrote:Looks like I will be going for bottom entry (ooh err missus ) just got to find the plumbing equivalent of what I know as a bulkhead fitting.
Bulkhead fitting
or visit your local pond/aquatic shop. I used something similar to pipe up my pond filter tank.
Re: Will it prime?
I use these or wherever supplies them cheapest....
https://www.toolstation.com/compression-tank-connector/p71736?store=FJ&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed
Re: Will it prime?
StuartTurnerSteve wrote:I use these or wherever supplies them cheapest....
"Compression tank connector" now I know what to look for, cheers Steve
Re: Will it prime?
Just another word for Bulkhead fitting.
Re: Will it prime?
Why not replace the elbow at the top left with an equal tee fitting. You can then fit a tap and funnel on the upward part of the tee for priming the pump. No need to makes holes in your tank.
Re: Will it prime?
blue cat wrote:Why not replace the elbow at the top left with an equal tee fitting. You can then fit a tap and funnel on the upward part of the tee for priming the pump. No need to makes holes in your tank.
Worth thinking about, a polished copper funnel would look nice.
Re: Will it prime?
Blue cat come on my friend, all a T will do is fill the bucket as the water will take the least resistive path.
Re: Will it prime?
maryalice wrote:blue cat wrote:Why not replace the elbow at the top left with an equal tee fitting. You can then fit a tap and funnel on the upward part of the tee for priming the pump. No need to makes holes in your tank.
Maryalice, I have something similar on my Blackstone pump, the water drops straight through the tee to the suction chamber, of course some may divert into the bucket, but all it needs is a small amount of water to reach the suction for the pump to prime. The water is added after the pump is turning but not necessarily pumping.
Re: Will it prime?
[quote="maryalice"][quote="blue cat"]Why not replace the elbow at the top left with an equal tee fitting. You can then fit a tap and funnel on the upward part of the tee for priming the pump. No need to makes holes in your tank.[/quote]
Maryalice [/quote]
Come on Mary from the Dairy, engage brain. Put a non return valve on the inlet side on the pipe in the bucket, then the water poured into the funnel will fill the pump and not the bucket.....
Maryalice [/quote]
Re: Will it prime?
Come on chaps, it's obvious it wont prime; there's too many breaks in that pipe.
Re: Will it prime?
oldgit wrote:Come on chaps, it's obvious it wont prime; there's too many breaks in that pipe.
Re: Will it prime?
It's to allow more water into the pipe instead of just picking up at the bottom
