lister ts1
lister ts1
Hello, looking for advice, i have old benford dumper with lister ts1, this is left hand crank and clockwise output, QUESTION, if i replace engine with a clockwise crank with anticlockwise output will this still drive dumper as normal, thanks in advance
eemeg- Posts : 2
Re: lister ts1
No it will go backwards based on what youve just described.
Re: lister ts1
oops
Re: lister ts1
Not sure about a Benford but I did drive a dumper once as a school holiday job. It had a separate forward/reverse lever. If yours is the same maybe you just have to twiddle to knob on top so the the dumper knows which way to go.
I guess the gears might not mesh properly if driven the wrong way?
» Lister D??
» OIL FOR LISTER D
» Lister D??
» OIL FOR LISTER D
