Piston Gudgeon Pin Cir clips
Hi all, anyone have at least 2 but better still 4 retaining cir clips for a Villiers MK 20 or 25 piston gudgeon pin, I have reassembled the engine using the clips I removed when replacing the cylinder complete with piston that I received from robotstar5 but although the removed ones fit I now think new ones will be better. will add the clips are similar in shape to a piston ring , lots smaller of course, they are not the type that would be used with in or out cir clip pliers
I have done a bit looking about but to date have not found any for sale or even advertised, possibly they are only available when a new piston or pin is bought, but as never needed to buy just these parts in the past maybe I am not looking in the correct places.
So help,suggestions or any ideas are welcome please.
Stay safe people as it does not seem to be getting any better, thank you, Don
donp- A credit to the forum
Re: Piston Gudgeon Pin Cir clips
You might try Cox and Turner.
Thanks Paul, email off to them,
Or....
https://www.lsengineers.co.uk/circlip-for-piston-on-villiers-mk20-mk25-engines-em132.html
Surely there must be an internal circlip available in the size from engineering stores.
Thanks again Paul, I looked at L & S site but could not see any.
Order will now be sent.
Excellent service from this L and S company, ordered yesterday 16/10/20 arrived today Sat. 17th.
Don
Don
» Help : Wolseley WD8 Piston and Gudgeon pin
» Wolseley WD2 float clips
» Villiers Midget Gudgeon Pin
» Piston Rings
» Lister D carb problems.
» Piston Rings
