Help with a Stationary Engine
+3
mattblack
SteveW
7 posters
Re: Help with a Stationary Engine
Hello and welcome!
I'm sure someone will be along shortly to identify your engine. Is it restorable? How much of a challenge do you like?
Petter diesel engine probably type PAZ1. Would be a fairly challenging restoration, at a minimum your going to need a fuel pump, air ducting and probably injector overhaul (and I'm assuming its not siezed). If it were mine I'd rescue any re-usable parts and give the rest a one way trip to China
Welcome sir
Garak- Life Member
Hi Steve and a warm welcome to the forum. That looks like a bit of a tough task - good luck!
Hello Steve,
Good to see that you made it here from 'the other place'. I knew the lads would give you a helpful welcome.
George B.
George B.
georgineer- Born to be wild
