Villiers ID/instruction plate.
Re: Villiers ID/instruction plate.
Robotstar5 wrote:I hope someone comes up with a source, I have a Mk.20 with the wrong smaller plate on too.
What is size is your plate? I have the wrong one that 'villiersparts' supplied, it may fit your engine.
The one I need is narrower but longer, there is no recess in the cowl.
You could try here:
https://www.vintagebrassplates.co.uk/stationary_engines_gallery.php
Though, to be honest, I've tried twice and never got a reply. Maybe you will have better luck.
mattblack wrote:Robotstar5 wrote:I hope someone comes up with a source, I have a Mk.20 with the wrong smaller plate on too.
The one currently fitted is 115mm wide by 100mm high, looks like I need about 125mm wide to fit the recess.
While measuring the plate I found another new one "in stock" and it measures 112mm wide by 87mm high, how many different sizes are there?
Matt,
How about finding one you could photograph, print onto water slide transfer paper and make an aluminium plate that the transfer can be attached to.
maryalice wrote:Matt,
If I could find a good one to photograph I could probably get one made by the company in the link above. A job for the future methinks.
Robotstar5 - the new one I have is 127mm X 102mm, the hole centres are 117mm X 92mm, it is the right one for the MK25 in my picture. It cost me £11, I'm happy to pass it on to you for the same rather than send it back.
@mattblack I'll measure my Mk.20 hole centres at the weekend and get back to you
» Villiers HT Lead threads on armature plate.
» Ruston Hornsby PB 1 1/2 with villiers magneto oil baffle plate
» INSTRUCTION MANUAL
» Help please : Instruction or service manual for Norman T300
» Pulsometer Pump...New project.
