amanco drip oller
amanco drip oller
what is the correct oil to use in the drip feeder to the cylinder the morris oils look ok but which one thanks
futura9838- Born to be wild
Re: amanco drip oller
30 Grade is the norm, but any good motor oil would do.
amanco drip oller
thanks for the reply i will get some ive had the engine running im just sorting little bits as i go along the oiler is black inside ive stripped it and will polish it up ive read they have a one way valve ie ball and pin to hold it my oiler dosent have this and there is no place for a pin to rest s this normal and does the oil blow back thanks tony
I've only owned my open crank, a Ruston Hornsby, for a few months so I cant really answer that question about your particular engine but there are a couple of others who should know the answer and are on here regularly.
futura9838 wrote:thanks for the reply i will get some ive had the engine running im just sorting little bits as i go along the oiler is black inside ive stripped it and will polish it up ive read they have a one way valve ie ball and pin to hold it my oiler dosent have this and there is no place for a pin to rest s this normal and does the oil blow back thanks tony
The Associated drip oiler does have a pressure release system. When viewed from the side a thin brass tube should be visible inside the glass.
This is the oiler from my 1914 Hired Man, it is a genuine one stamped on the top by Associated. If yours does not look like this it's possibly a replacement.
Garak- Life Member
