Lister D fuel
Lister D fuel
I'm new to this stationary engine game, so I was thinking with all the problems with this new E10 petrol and vintage cars. Is it OK for use in something like a Lister D.
If not what do you use ?
Pump hand- Born to be wild
Re: Lister D fuel
E10 wont hurt youve no parts in a D for the petrol to attack.
Re: Lister D fuel
Only thing I would do is run the float chamber dry when shutting down.
Re: Lister D fuel
As well as, either fully filling to the top, or completely draining the fuel tank, over winter or if laying up for an extended period. This will help to reduce the effects of water absorption caused by the ethanol, collecting at the bottom of the tank making starting difficult to impossible and or rusting the tank out.
Neil.
Neil.
» Lister D Fuel Question
» Lister D run up without fuel tank
» Lister D Fuel Tank
» Lister d Fuel bowl
» Lister D Fuel tap replacement
