Piston pattern for Robinson x type
A bit of a long shot but has anyone made a pattern for a piston for a Robinson x type gas engine.
Gaudin98- Expert
Re: Piston pattern for Robinson x type
If you can't find a pattern, then you could use a Lister D piston as a pattern, I think they are pretty well the same size (3").
blue cat wrote:If you can't find a pattern, then you could use a Lister D piston as a pattern, I think they are pretty well the same size (3").
Yes, Peter Keating's Robinson uses a Lister D piston and I'm guessing that a Ruston PT or Wolseley WD one would fit as well?
Many thanks for your suggestions. It has had a Lister D piston fitted on a previous attempted restoration. I wish to replace it with one of the original type.
Gaudin98- Expert
