petter a 1947 crank pin diametewr
hi please can a kind member tell me the crank pin /big end journal size for a std petter A 1947 thank you
martin418- I really need to post more
Re: petter a 1947 crank pin diametewr
Sorry, only just spotted your post. Can you confirm model is A , A1 , A11 ... though internally they are generally much the same.
hi its an A
Hi,
The (A1) user manual I have doesn't give dimensions and the A range workshop manual I have is for later A series engines (but crank diameter is shown as 1.6250/1.6245")
L&S Engineers and Stationary Engines Parts have shells for various vintage engines so may be worth an email to see if they have any info.
Good Luck
Good Luck
thank you for looking , it measures 1.7498'' as does the mains so i think its std , as they say i will continue the research
