Please confirm what this is please.......
......I think it's a Petter PAZ 1 can someone confirm this as the brass plate is not one the engine as I believe some tin-work is missing from around the cylinder where the ID plate would have been.
It's a barn find and I think it has been in a concrete mixer as it is covered in cement powder.
Also is it a first or second series engine?
Thanks for any information
Garak- Life Member
Re: Please confirm what this is please.......
Robotstar5 wrote:Looks very much like my PAZ1
Thanks Stuart, it does look identical.
I was wrong in assuming that the one I found was missing some tin-work around the cylinder, yours does not have it in that area also.
Thanks again
Martyn
Garak- Life Member
That is a'second series' engine, I had an early one for a while (pic enclosed) and the flywheel was enclosed and it had a different governor setup. It should have a tin shroud around the cylinder, obviously missing.
Thanks again
Martyn
Just checked my pics and it did come with more tinwork, it just wasn't fitted.
Bottom right in pic from when I collected it.
