Fluorescent Tube Transformer
Years ago the transformer from a flori tube could be used to create a spark to use on our engines. This would also be used along with a battery not necessarily a 12 volt source. Problem is, I can’t remember how to wire it up
Any of you peeps can guide me please?
Meanwhile I’ll keep searching
Thank you in advance
G
G
If Fossil fuels aren’t involved I ain’t interested
Guldner- Born to be wild
Re: Fluorescent Tube Transformer
Oops
Doing a bit of searching….. the setup is for low tension internal igniter ie Amancos…
You get a spark across the points no a spark plug
Indeed for use with low tension ignition systems only. It's not a transformer either (as there is no secondary coil), it's a choke (sometimes called a ballast, or inductor).
Depending on what you want to get running you can also use an automotive coil and a battery on a magneto thats got a dead coil if thats something which will help you out.
Thank you Christmac
That’s exactly what I’m using on a shaft Lister D….which I want to know what a correct shaft coupling looks like
» Gardner 1F gas hot tube
» Deutz 1904 hot tube
» What's the best material for an ignition tube?
