Armstrong Siddeley diesel engine...
Armstrong Siddeley diesel engine... Empty Armstrong Siddeley diesel engine...
Post by casper Sun Feb 06 2011, 15:55
Well, i've bought another old diesel. An Armstrong Siddeley single cylinder. The serial number is DE13477. It says 8hp at 1200rpm. I've had it running and it goes okay. It hadn't been started for a few months and produced a load of black smoke at first..
Anyone got any information on these, maybe a manual?
Armstrong Siddeley diesel engine... Brass062
Armstrong Siddeley diesel engine... Brass064
Get an after life..
casper
casper
Armstrong Siddeley diesel engine... Empty Re: Armstrong Siddeley diesel engine...
Post by casper Sun Feb 20 2011, 15:13
I've bought some nice old steel wheels, which have S Corbett & Son, Wellington, Shropshire stamped on them. Made a strong trolley for this engine and it's now fitted onto it. Can't start it properly yet as first i'm going to clean out the fuel tank and lines as there is a lot of crud in the fuel filter!!
Armstrong Siddeley diesel engine... Delete001
Armstrong Siddeley diesel engine... Delete002
Armstrong Siddeley diesel engine... Armstrongsiddeley001
Get an after life..
casper
casper
Post by Guest Sun Feb 20 2011, 16:32
Looks good Gary,
mines very similar, but has a different tank bracket arrangement, and doesnt have tow outputs on the timing casing end, just the half speed for starting, i use a modified ferguson tef starting handle for cranking it over.
Cheers,
Paul. Very Happy
Post by casper Wed Apr 06 2011, 13:34
Started this engine for the first time today, really needs a good run and a service but at least it did start....
Captured a video of the event, loads of smoke too....
https://www.youtube.com/watch?v=OXYwZ_xfeK0&feature=player_embedded#at=13
Gary
Get an after life..
casper
casper
Post by Guest Wed Apr 06 2011, 14:15
Looks like a nice lump. In my opinion it seems to be putting out a bit of blue smoke as well as the black. If you check this one out you'll see what I mean.
https://www.youtube.com/watch?v=UZrAzJu550k&feature=fvwkrel Maybe a good run with a load on it might help to settle it back in after it been stood.
Post by billypurves Wed Apr 06 2011, 20:52
Sorry I cannot help much with engine but I would say not to run it again with the washing hanging out, easiest way to get your slapped that I know.
billypurves
billypurves
Post by Admin Wed Apr 06 2011, 21:36
billypurves wrote:Sorry I cannot help much with engine but I would say not to run it again with the washing hanging out, easiest way to get your slapped that I know.
lol! lol! lol! Billy has some one had a cuff on the lug before?
If so snap.
Garry, See when you crank an engine over please watch your thumbs in case the engine kicks back, you will have broken thumbs of not.
Post by JONESEY Wed Apr 06 2011, 23:33
Paul ,Gary will only do it the once Laughing Laughing Try putting some clean engine oil in it ,change it a couple of times see if that helps the smoke.
Sounds good Smile
if it was my engine I think I would mount it on a wider trolly looks a bit top heavy
Jonesey Smile
